CTFC_Bennn
Mar 19, 2025Aspirant
EX2700 Keeps losing connection
Hi everyone I have had this extender for over 4 years now and it has worked perfectly ever since. I recently got a new router and I managed to connect it to my extender just fine. However I found...
CTFC_Bennn
I have already factory reset the extender and it didn't change anything. I never had this problem with the previous router
Mar 20, 2025Guru - Experienced User
did you use the installation assistant?
What router did you add?
Are you using mixed wpa2/wpa3 mode on the new router?
where does it fail in the install process?
