Fraydumfries
Jul 27, 2023Aspirant
EX2700 n300 range extender
I have an ex2700 router extender and have just tried to connect to a new router. However, it won't bring up the Web page to login. I have factory reset and checked the address but I get an error messa...
Jul 28, 2023Guru - Experienced User
you factory reset?
And it shows the the netgear_ext option?
did you try 192.168.1.250
- FraydumfriesJul 31, 2023Aspirant
I did factory reset the extender and it was showing the netgear ext but wouldn't connect to the website. What is 192.168.1.250?
- plemansJul 31, 2023Guru - Experienced User
that's its default ip address if its not setup (as then the router would assign one)
- FraydumfriesAug 01, 2023Aspirant
Hi there, really appreciate the response but I am not the most tech literate. What would I need the default ip for? Should I input this into somewhere?
