Fraydumfries
Jul 27, 2023Aspirant
EX2700 n300 range extender
I have an ex2700 router extender and have just tried to connect to a new router. However, it won't bring up the Web page to login. I have factory reset and checked the address but I get an error messa...
Jul 28, 2023Guru - Experienced User
you factory reset?
And it shows the the netgear_ext option?
did you try 192.168.1.250
Fraydumfries
Jul 31, 2023Aspirant
I did factory reset the extender and it was showing the netgear ext but wouldn't connect to the website. What is 192.168.1.250?
