Fraydumfries
Jul 27, 2023Aspirant
EX2700 n300 range extender
I have an ex2700 router extender and have just tried to connect to a new router. However, it won't bring up the Web page to login. I have factory reset and checked the address but I get an error messa...
Fraydumfries
Jul 31, 2023Aspirant
I did factory reset the extender and it was showing the netgear ext but wouldn't connect to the website. What is 192.168.1.250?
Jul 31, 2023Guru - Experienced User
that's its default ip address if its not setup (as then the router would assign one)
- FraydumfriesAug 01, 2023Aspirant
Hi there, really appreciate the response but I am not the most tech literate. What would I need the default ip for? Should I input this into somewhere?
- DexterJBAug 08, 2023NETGEAR Moderator
Hi Fraydumfries , yes, once the device you're using for setup is connected to the default Wi-Fi name of the extender you'll have to open up a web browser (Chrome, Firefox, etc.) and input the numbers on the address bar.
Also, you can always reach our support team via the link below if you need any technical assistance with your NETGEAR device.
https://www.netgear.com/about/contact-us/
You can also call the number below.
1-888-NETGEAR (1-888-6384327)
Dexter
NETGEAR Team
