talljr1
Jul 31, 2016Aspirant
EX2700 OR EX3700 AS ACCESS POINT
Can I hardwire the 2700/3700 to an ATT Uverse Modem/Router? I have tried other extenders and they seem to be unreliable (dropping connection for example). I was thinking that hardwiring would make it...
talljr1
Aug 01, 2016Aspirant
Thank you very much and just so I am clear, this is how it will work.
I can run an ethernet cable from my UVERSE Router/Modem to the EX3700. The Uverse unit will still have WIFI via my current SSID. When I setup the EX3700, I can name that WIFI SSID the same name, correct? That way, when I move between the zones or access points, it will pick up the strongest signal.
talljr1
I'm glad I read the reviews on Newegg to discover the Ethernet port is not a 1GB port. Not really worth it to run a hard line to my router if I am only getting 100mb.
