98joscro
Apr 30, 2021Follower
EX2700 Password Issues
Hi, Having issues setting up this wifi extender. When I connect to the network it asks for a password I have tried the default "password" and it doesn't work. I have tried getting on to mywifiext...
Apr 30, 2021Guru - Experienced User
Did you set it up using wps?
If so, try factory resetting the extender (push and hold reset for 7-15 seconds while powered on).
then use the installation assistant for setup and not wps.
