Prostel006
Apr 16, 2020Follower
EX2700 password problem
Hello , just bought this and it connected to my wifi router but it won’t let me connect any device to it , keep telling me that password is incorrect . I connected it to my vodafone wifi router troug...
- Apr 16, 2020
ISP supplied routers aren't known for their wps function being coded the same. This can create issues. Its also why Netgear has a secondary install method using the installation wizard.
Factory reset the extender and follow the installation guide using the wizard and not using the wps method. See if that works.
Apr 16, 2020Guru - Experienced User
