Kirpa's avatar
Kirpa
ex2700 password set up blunder - how to fix
Just trying to set up a Netgear EX2700 extender and mistakenly entered the wrong passord for connecting to my wifi and am now stuck in a closed loop. I tried to reset to factory settings but it automatically defaults to the xxxxxx_EXT I created (with erroneous password) in the first place.   I am so out of my depth here.  Can someone please take me through the steps to correct my blunder.  I am doing the set-up through a cable as my router is not WPS enabling.  That's the sitch!  Thank you.
1 Reply
  • plemans's avatar
    many people just click reset.
    It needs to be pushed and held in while the device is powered on. usually 7-15 seconds.
    the lights will change when its held long enough.
    did you try that?
