JonMP64
Oct 03, 2021Follower
EX2700 Range Extender Essentials Edition
I have purchased the EX2700 Range Extender UK version, three pin plug, can I use this in Jamaica with a simple plug adapter? Thanks
If the power (voltage/hz) is the same, you should be able to but you might need to change the region code so you're not in violation of regional broadcast issues.
1 Reply
