Gadgetman43
Jan 18, 2025Aspirant
EX2700 Range extender. Unable to access.
Recently reinstalled an EX2700 range extender. It is connected to my WiFi and can be identified as so, on the BT hub (router). Confirmed by being able to see the Mac and IP address. Atempting to acc...
Jan 20, 2025Guru - Experienced User
If you set it up with wps, factory reset the device. then install it using the installation assistant and not wps.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Gadgetman43
Jan 21, 2025Aspirant
Hi
Sadly, I have seen that video before. The fact is I cannot access the device in the first place. It shows on my router which indicates it "sees" the system. but still won`t allow access to the Log On. Entering the IP address is not recognised. Setup with WPS fails.
Pete
- plemansJan 21, 2025Guru - Experienced User
If you tried wps, factory reset it.
Then hardwire a PC/laptop into the extender (shut off the pc/laptops wifi) and go to 192.168.1.250 or mywifiext . net
