JHEAD
May 04, 2022Follower
EX2700 REFUSES TO ACCEPT ROUTER PASSWORD
I have 3 Netgear EX2700's and even though I have carefully reset and reconnected with WPS, they still refuse to accept my router's password. Cheers, feel like throwing them away and buying new ones. ...
May 04, 2022Guru - Experienced User
all 3 are having the issue?
What router are you connecting them to?
are you setting them up using wps or using the installation assistant? (highly recommend the assistant over wps)
