pjg542
May 30, 2020Initiate
EX2700 same password as router but rejects "incorrect password"
Windows 10 Router / Modem Big Blu net via satellite - same password on extender as router BUT rejects "incorrect password"
- May 30, 2020
did you set it up via wps?
If so, factory reset it and run setup using the installation wizard.
Wps isn't coded the same between different manufacturers and so when it doesn't work, that's when you use the installation wizard.
May 30, 2020Guru - Experienced User
- pjg542Jun 07, 2020Initiate
Thanks for solution!
