Falkie
Aug 28, 2018Aspirant
EX2700 Security issue
I saw a post on here where someone has the same problem. Avast wifi checker comes up with a message when scanning the security of my network saying that it is vulnerable (on both extenders I use) to ...
- Sep 01, 2018
uPNP isn't part of DNSMASQ ( https://en.wikipedia.org/wiki/Dnsmasq )
uPNP is described here: https://en.wikipedia.org/wiki/Universal_Plug_and_Play It includes a way for a program to tell your router to open a port in the firewall. That can simplify your router setup, but malware can use it to expose your home network as part of its attack.
Look in your BT router configuration - most routers have a way to disable uPNP. That only disables the ability for a program to open a firewall port - you can still run uPNP software (for instance DLNA media servers and players) on your home network. Though there are some programs that rely on the firewall management feature - so keep an eye out for misbehaving software if you do disable it.
Aug 28, 2018Guru - Experienced User
uPNP would only be a potential security threat if it were enabled on the router. The extender can't open up ports in the router firewall.
- FalkieAug 28, 2018Aspirant
Thanks for that StephenB - very helpful. I think that the problem must lie with the BT router then. The Avast security check also shows that as being vulnerable. BT say that this vulenerabilty has been patched "The most recet firmware that was released by BT (SG4B1000B540) has not updated the DNSMASQ version number, however a patch was included which counteracts the vulnerability. Terefore any customer on the new firmware is protected but Avast will still throw up a warning message...."
They say they will fix this but have not done so yet.
I've no idea what a DNSMASQ is, but does that sound like it might explain it all ? Thanks again for your help. Much appreciated !
- StephenBSep 01, 2018Guru - Experienced User
- FalkieSep 02, 2018Aspirant
Thanks very much for your help. I find that one learns something new every day and I enjoyed trying to get to grips with these terms ! I found out how to disable UPnP on the BT router (home/advanced settings/firewall/configuration) and then there is a button to disable UPnP. However, it made no difference so I re-enabled it. I think I will just have to wait for BT to properly update the firmware on this router. Cheers and thanks your help
