ArsyMarci
Apr 19, 2020Aspirant
EX2700 seems to have caused issues with my wifi
I have a Sky Q hub but have always had one room in the house that is a bit of a wifi black spot. As we are in lockdown and it is my sons bedroom that is affected, I bought a EX27200 extender, plugge...
- Apr 19, 2020Only once lockdown is lifted apparently! Thanks for trying to help 🙂
ArsyMarci
Not any more :( Intermittently at best, and even then it’s very very slow
- plemansApr 19, 2020Guru - Experienced User
If the extender is unplugged and you're still having issues, the extender isn't the issue. The router is.
Mabye try factory resetting the router and re-install it.
What router is it?
- ArsyMarciApr 19, 2020AspirantI think it must be. I’ve tried reboot and factory reset and it’s no better. It’s a Sky Q Hub - model ER115.
The sky router might have joined its friends in the great graveyard in the "sky".
If its rented from your isp, they should be responsible for replacing it.
