maddierules
Aug 23, 2024Aspirant
ex2700 setup not showing access point as an option. ONLY showing WIFI extender
I moved my ex2700 from one office to another. Performed full reset. When I accessed the device to run the new set up it the software only shows option for wifi extender and not access point. WHEN...
maddierules
Aug 24, 2024Aspirant
It has a CAT 5 connection on the top of the unit and it was being used that way for the past year, so I am confused. I appreciate your reply.
Aug 25, 2024Guru - Experienced User
It does have an ethernet port. that is used to connect devices (computers/tvs/etc) to.
Without an AP mode, it won't connect directly to your router through it.
