tkemp
Aug 14, 2019Follower
EX2700 Slow Wifi Speeds
We've been looking for a range extender solution on the cheaper end, and decided to try the EX2700. Easy to connect and hook up, but the wireless speeds are horrid no matter what we do. We have tried...
Christian_R
Aug 19, 2019NETGEAR Employee Retired
Hello tkemp - Have you tried changing the wireless channels on your router? Would you mind telling us what firmware version your extender is on? Also, if you recently purchased the device, your device is provided with 90 days of complimentary support which can be accessed using the link below.
https://www.netgear.com/support/default.aspx
~Christian
