tattooedpariah
Sep 10, 2020Tutor
EX2700 sudden failure
So I have a C7800v2 modem/router and two EX2700 extenders. They have worked flawlessly for about 8 months now. Yesterday, I was going to fire up my grill (it's wifi enabled..) and i loaded the a...
- Sep 10, 2020
try setting the C7800's "up to speed" for the 2.4ghz down a notch.
tattooedpariah
Sep 11, 2020Tutor
alright, I was 100% skeptical and didn't want to do it, but setting the 2.4Ghz to "up to 433Mbps" did in fact work at getting the "router" led lit up again on the extenders...
just set it back to 1000Mbps and they seem to be staying lit for now..
Thank you all!
Sep 11, 2020Guru - Experienced User
Glad to hear it worked! if you mark it as solved it can potentially help the next person with this issue
