Iantell
Feb 23, 2020Aspirant
Ex2700 won’t connect to router
My wifi extender suddenly stopped outputting signal. Router will not connect. My router connects to all other wifi devices. Performed Factory reset on wifi range extender and it will still not connect...
Iantell
I did the factory reset, I’m not sure what firmware is on the router to be honest or how to update it if that is a thing, it is just my standard wifi router, I tried both wps and manual installation
Feb 23, 2020Guru - Experienced User
What router is it? this is kind of key as its usually a router issue when extenders don't connect.
When you're logging into the extender, the main status page should list its firwmare. Which version are you on?
- IantellFeb 23, 2020AspirantIt’s a Rogers modem model: cgn3acsm,
When I try to log on to it it wants me to connect to the wifi and it won’t connect to the router- plemansFeb 24, 2020Guru - Experienced User
When I try to log on to it it wants me to connect to the wifi and it won’t connect to the routerWhat error is it giving you?
Did you try resetting the Rogers device?
- IantellFeb 24, 2020AspirantIt’s not giving me an error as far as I know it’s just not connecting to the router, yes I’ve reset the router
