Lupaja1983
Nov 12, 2017Follower
EX2700
Hi, i have been using my extender for long time with no problems; i have recently change my internet supplier and consequently the modem.
After i did the normal process to configure the device, i put the password (which perfectly works without extender) and it says that the password is incorrect but i can see that the electronic device has been reconised.
What could it be??
Thanks Andrea
What could it be??
Thanks Andrea
1 Reply
- DarrenMSr. NETGEAR Moderator
Try to log into www.mywifiext.net and change the password again on the extender and see if that works for you.
DarrenM
