leev55's avatar
leev55
Follower
Apr 18, 2020
ex2700
I have connected my range extender to the router successfully, plugged it in where I need it and get a good connection signal. However the device light is off. When I take a device to it I put in the network password as instructed. the light flashes green and the device then says that it cannot access it due to the wrong password. I have been V careful to get the password right!
Any suggestions?
Lee
1 Reply
  • plemans's avatar
    did you set it up via wps?
    If so, factory reset the extender and rerun setup using the install wizard and not wps.
