LL2020
Oct 23, 2020Follower
Ex2700
I have connected the extender to my router, but when I try to connect my phone or iPad it says the password is wrong. But it says to use the current router Password. I have checked the password and it is correct. Can anyone help please. I’m not very technical so basic advice would be great please! Thank you
1 Reply
What router are you connecting it to?
What firmware is on it?
Did you set it up using wps or using the installation assistant?I'd highly recommend using the installation assistant if you didn't. Factory reset the extender and reinstall it using that method. don't use wps.
