inesllopart's avatar
inesllopart
Initiate
Mar 31, 2021
EX2700
Hi, I have an old Wifi Extender at home and I am trying to follow the device's instructions.
However, when the Power LED goes green no wifi network shows up to start the setup. Has this happened to anybody else? Any ideas how to solve it? My router also does not have a WPS button.
Thank you!
  • did you factory reset the extender? Maybe an old ssid is broadcasting.
    Push and hold reset for 7-15 seconds while its powered on. Then try setup
  • plemans's avatar
    • inesllopart's avatar
      inesllopart
      Initiate
      Thank you! It turns out I wasn't holding the reset button for long enough
      • plemans's avatar
        Glad it was something simple! :)
