roaringbranch
Mar 22, 2020Aspirant
EX2700|N300 WiFi Range Extender
I have an existing range extender which suddenly wants me to do a "NEW EXTENDER SETUP". I guess it reset itself? However whenever I go through the setup, I get an error message that my "timestamp exp...
Mar 22, 2020Guru - Experienced User
1. do the setup over a hardwired connection. tends to go smoother and work better.
2. try a different browser or pc/laptop. maybe its an issue with the browser or device.
- roaringbranchMar 23, 2020Aspirant
Thanks for the suggestions. I've now tried on my wireless ipad and hardwired desktop with Safari, Firefox, and Chrome. The results are the same every time, timestamp expired. It only takes a minute or less to fill in the username, password, and security questions. It seems like a Netgear bug, but I don't know how to get their attention. Frustrated.
- plemansMar 24, 2020Guru - Experienced User
Have you tried factory resetting the extender?
push and hold reset for 7-15 seconds while the device is powered on?
Anothing thing to check is popup blockers or firewalls.
again, that error is usually fixed with a clear cache/cookings, changing browsers, or devices.
