emcguy
May 08, 2024Initiate
EX2800 log in
I purchased a EX2800 extender some time ago. Had no issues setting up and using it. I recently upgraded to a newer router. I followed the usual and connected the extender through WPS with no problem....
- May 09, 2024
If you set it up using the push button WPS option, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
May 09, 2024Guru - Experienced User
emcguy
May 09, 2024Initiate
After doing that, and installing firmware upgrade, It works now
Thanks
- plemansMay 10, 2024Guru - Experienced User
Glad you got it working!
Might be time to keep an eye out for a better extender. that's a pretty old/slow extender so if you're using it for more than IoT devices, its bottlenecking big time
