emcguy's avatar
emcguy
Initiate
May 08, 2024
EX2800 log in
I purchased a EX2800 extender some time ago. Had no issues setting up and using it. I recently upgraded to a newer router. I followed the usual and connected the extender through WPS with no problem....
  • plemans's avatar
    May 09, 2024
    If you set it up using the push button WPS option, factory reset the extender and set it up using the installation assistant.
    To factory reset, push and hold the reset button for 7-15 seconds while powered on.
    Here's a video of how to use the assistant.
    https://www.youtube.com/watch?v=yJVklshxBMk
