MyRangeExtend
Aug 28, 2020Follower
EX3110 – AC750 Dual Band WiFi Range Extender compatible with Zyxel Router?
Are the EX3110 – AC750 Dual Band WiFi Range Extender compatible with Zyxel Router?
Aug 29, 2020Guru - Experienced User
Most extenders are compatible. But not all can be installed using wps. In those cases, you using the installation assistant
