stanko2
Dec 24, 2021Follower
EX3110 – AC750 Dual Band WiFi Range Extender
HI I have install ex3110 whit the help of Netgear support person after installation I check the Speed it come only 50.7 mbps whit out extender go over 150mbps .I contact the Netgear support but I d...
nielsvds
Dec 24, 2021Luminary
When you performed the test did you also connected to the same band? At a longer distance speeds on the 5Ghz band will be lower. Try the same speedtest when connected to the 2,4 Ghz band. The extended network will be called "yourexistingwi-finame"_2GEXT. See what your result is now. What colour does the router LED has?
