marc_e
May 24, 2023Initiate
EX3110 AC750
I installed my extender and have no issues connecting to its SSID on either band. However, after installing it, I can no longer connect to my original wifi SSID from any device. Any ideas what mi...
May 24, 2023Guru - Experienced User
What router is it?
did you setup the extender using wps or using the installation assistant?
marc_e
wps
- plemansMay 24, 2023Guru - Experienced User
Factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
