ArkanShawGamer
Oct 24, 2022Tutor
EX3110 Install
When installing my recently purchased Netgear EX3110 I get both Power/WPS lights solid green. The wifi name/s 2.4Ghz/5Ghz comes up. I enter my password for my router and I keep getting invalid passwor...
- Oct 25, 2022
Hmmm. Sounds familiar.
D-Link host router?
Have you disabled Smart Connect on the host router then used the NIghthawk app to get it connected to the host router? If you did and the extender isn't working right at a far distance, I'd consider taking the extender back and trying a another one...
Oct 25, 2022Guru - Experienced User
D-Link host router?
- ArkanShawGamerOct 25, 2022TutorThat worked!!!
- DeopenaNov 10, 2022AspirantNot at all
