ArkanShawGamer
Oct 24, 2022Tutor
EX3110 Install
When installing my recently purchased Netgear EX3110 I get both Power/WPS lights solid green. The wifi name/s 2.4Ghz/5Ghz comes up. I enter my password for my router and I keep getting invalid passwor...
- Oct 25, 2022
Hmmm. Sounds familiar.
D-Link host router?
Have you disabled Smart Connect on the host router then used the NIghthawk app to get it connected to the host router? If you did and the extender isn't working right at a far distance, I'd consider taking the extender back and trying a another one...
Oct 25, 2022Guru - Experienced User
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
ArkanShawGamer
Oct 25, 2022Tutor
Yes it was Push button WPS. I reached out to my son and he said my new D-Link Router has Smart Connect and to disable it. Once I did that It worked properly. Thx for the reply!!
- FURRYe38Oct 25, 2022Guru - Experienced User
Awe, glad he helped you get it working.
Enjoy. đ
