LeeLea
Sep 08, 2022Follower
Ex3110 password
New ex3110 wifi extender will not accept password on router while I’m setting up. Help please.
1 Reply
What router are you connecting it to?
Are you trying to set it up using the WPS push button method or using the installation assistant?
If you're using wps, try factory resetting the extender and using the installation assistant and NOT wps.
