Tentis
Jan 02, 2021Follower
EX3110
The WiFi password we use for our router won’t work for the WiFi’s we have from our extender.
1 Reply
What router did you connect it to?
Did you set it up using wps? It doesn't always get coded the same between manufacturers. Try resetting the extender and installing witht he installation assistant
