BGinUK
Aug 13, 2020Follower
EX3700 - Problems installing
My son has just purchased an EX3700 wifi range extender: The extender does not connect to our router using WPS When I try to connect to either: XXX_2GEXT or XXX_5GEXT with our routers password ...
Fbrownstein
Dec 29, 2020Aspirant
I have exact same issue. I found where I can pay $10 for support but I can buy a new extendet for $30.
- plemansDec 30, 2020Guru - Experienced User
Fbrownstein or you could start your own thread instead of jumping on others....then we'd be happy to help you.
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/EX3700-Firmware/m-p/2030307#M44922
