Darwin4Ever
Feb 24, 2023Tutor
EX3700-100PES
Hi, I'm struggling again with my EX3700-100PES configuration. Really this configuration is over-complicated Two years ago I finally managed to have it working as an Extender (ONLY for the LAN...
Feb 24, 2023Guru - Experienced User
Why are you disabling the ssid broadcast?
Maybe last time you changed something else.
Does it stay working if you leave them enabled?
What router are you connecting it to?
Darwin4Ever
Feb 24, 2023Tutor
Because I need the EX3700-100PES only for it's LAN-port
Probably but I can't remember as I struggled then too and got it finally working without knowing why it did in the end
I haven't tried that. But the DesktopPC connect over the LAN through the RouterLink, so the broadcasts shouldn't be involved ?
The old Wifi-network was an Proxim AP-600
When I changed in the WebUI it's SSID to the new SSID, I lost control too, reason why I restarted with a reset
The new WiFi-Network is part of the FritzBox 7490.
- plemansFeb 24, 2023Guru - Experienced User
Leave the wifi ssid enabled and see if it works
- Darwin4EverFeb 25, 2023Tutor
There is no difference when SSID Broadcast is enabled.
I found the reason (but not why) of the problem : when both 2G and 5G Router SSID links are configured it doesn't work.
When I only setup the EX3700-100PES for the 2G SSID, the problem is gone.
I discovered also a bug in the Router SSID manual step of the setup.
It's possible to copy/paste the SSID, but if you do so, there is no way to enter or copy/paste the key.
