stmiranda
May 23, 2019Tutor
EX3700 5Ghz shows disabled
Hello, My apologies if this has been discussed. From the attached you can see the 5Ghz network is showing disabled and in the general settings there is no 5G option. Only the 2.4. Any idea how to c...
- May 24, 2019
Essentially, the "disabled" is a bad wording - there should be an indication that your EX3700 is configured into FastLane mode instead - with the 5 GHz radio used for the uplink to the router, and only providing an AP on 2.4 GHz.
Head to the menu "Do more" -> "FastLane" ... convinced you find the EX3700 is set to FastLane mode .. so change it to the Basic mode. Now you will have to establish connections to the router on both the 2.4 and 5 GHz bands and SSID, and get both Access Point radios enabled.
schumaku
May 24, 2019Guru - Experienced User
stmiranda
May 24, 2019Tutor
Brilliant -- thank you very much for the explaination. You were spot on.
Cheers,
Steven
