spitlist
Sep 18, 2022Aspirant
EX3700 Access Point Mode is SLOW
I installed the extender in the Access point mode and it is working, but when I ran a speed test, I found that the download speed is less than 10 mbps while the WIFI speed directly to the router is 2...
Sep 18, 2022Guru - Experienced User
Are you testing the 2.4ghz or the 5ghz?
Are you sure its setup in access point mode?
- spitlistSep 18, 2022Aspirant
I have tested it in both modes and get the same speed (les than 10 mbps). I set it up in Access Point Mode with the help of a tech support person, so I am quite sure it is set up correctly.
- plemansSep 19, 2022Guru - Experienced User
I'm never trusting of others because I don't know what they did/setup.
You could try factory resetting the extender and redoing setup. Maybe something was done wrong or maybe it was setup in fastlane improperly.
- spitlistSep 19, 2022Aspirant
During the setup, one of the things we did was reset it to factory settings. From the very start, this extender setup was troublesome. I could never get the setup screen after connecting to the NETGEAR_EXT WIFI network. That is why I contacted NETGEAR Technical support. The young lady went through a number of things with me (after resetting to the factory settings) and finally got the "NEW EXTENDER SETUP" button to appear. The thing is working and I can watch videos on my computer connected to the NETGEAR_5GEXT or NETGEAR_2GEXT WIFI options without if constantly searching, but when I run the speed test on either one, it is under 10mbps. So I naturally wondered why. I selected the Access point option after reading that using the WIFI Extender mode would slow down the signal. Naturally, I was surprised to discover that the Access Point option also was much slower than expected.
