Yakuruna
Nov 18, 2019Tutor
EX3700 all lights on but no internet
Hello, I have been using a Netgear EX7300 in extender mode for nearly a year and it has worked really well. I am connected to a BT Smart Hub router. A few days ago the internet connection became...
- Nov 18, 2019
1. What firmware is on the extender? I know you say the latest but a number helps.
2. Are you using fastlane or just standard extender setup?
3. Have you tried changing wifi channels? sometimes neighbors change router settings and it causes interference with yours. a channel change can help sometimes.
4. Is it only 1 radio havingg issues or are both 2.4ghz and 5ghz having the issue.
Yakuruna
Nov 20, 2019Tutor
Thanks for your reply Plemans, I thought it was solved as once I changed the wifi channels it worked again but only for a short time.
1. My firmware is v1.0.2.140.
2. I am not using the fastlane
3. Wifi channel change did not help
4. Both radio having the issue.
with further investigation it seems that my iPhone works ok. Also my Mac connects ok. The problem is with my PC and I see in the bottom left corner "resolving host" when my browser is trying to load the page
thanks
Chris
Nov 20, 2019Guru - Experienced User
So everything but a single PC works fine? is that correct?
If so, I'd be more inclined to think its the PC that's having the issue and not the extender.
- YakurunaNov 20, 2019Tutor
Yes that's correct.
Would you have any lines of investigation with the PC? I am running windows 10.
thanks
Chris
- plemansNov 20, 2019Guru - Experienced User
What wireless adapter are you using?
Is the pc close enough you could just plug into the ethernet port on the extender?
I am using an Apple Macbook Pro with Bootcamp loaded with Windows 10. Starting up in OS X works fine with the extender, just not from Windows. If I look at network connections in windows it says the adapter is 802.11ac Network Adapter.
I just tried connecting to the extender using an ethernet cable but I still get no internet
