FDOliver
Sep 20, 2020Follower
ex3700 Cant connect to a new wifi
I have been using a netgear Wi-Fi range extender (model EX3700) for 2 years and recently had to buy a new Wi-Fi Router. I am not able to set the existing WiFi range extender to the new router because...
Sep 21, 2020Guru - Experienced User
when many reset, they don't push and hold the button. While the ex3700 is powered on, push and hold reset for 7-15 seconds. the lights should flash when held long enough.
then go through setup.
If it doesn't work, try hardwiring into the extender with a pc/laptop and trying setup. Just make sure that whatever pc/laptop you connect to it has the wifi disabled so it doesn't default back to wifi during setup.
