Rondo457
May 10, 2019Aspirant
EX3700 connected but no internet
Rondo457
EX3700. Went thru Network Genie numerous times with Netgear. Factory resets.
Netgear software indicates successful install. All lites on extender are green. Device lite turns green when _ext network selected. Spectrum Internet with SagemCom router. Spectrum
tech people have looked at system with no success.
- plemansMay 10, 2019Guru - Experienced User
if you hardwire into the extender, does it work?
Are you able to pull up the extenders gui from a browser (not genie)? mywifiext.net
What firmware do you have installed to the extender?
What sagecom router/combo device (model)? Does it use a smart connect function (one ssid name)? if so, shut it off.
- Rondo457May 11, 2019Aspirant
Hardwire into extender does not work.."unidentified network"....no internet/all lites green/ same response as wireless.Extender GUI 192.168.1.250 does work from Google/ChromeNo firmware installed...straight out of the box.Spectrum Sagemcom Router/ 802.11ac wave 2-askey routerModel# RAC2V1K. No smart connect function. I suspect this extendermodel has been around several years. Thanks again.
Thanks- Christian_RMay 16, 2019NETGEAR Employee Retired
Hello Rondo457,
Please try factory resetting the extender by pressing on the small black button using a pin for 15+ seconds and join the NETGEAR_EXT wifi network with a laptop or mobile device. After you connect to the network, browse to www.mywifiext.net and follow the setup instructions.
~Christian
