Rondo457
May 10, 2019Aspirant
EX3700 connected but no internet
Rondo457
EX3700. Went thru Network Genie numerous times with Netgear. Factory resets.
Netgear software indicates successful install. All lites on extender are green. Device lite turns green when _ext network selected. Spectrum Internet with SagemCom router. Spectrum
tech people have looked at system with no success.
May 10, 2019Guru - Experienced User
if you hardwire into the extender, does it work?
Are you able to pull up the extenders gui from a browser (not genie)? mywifiext.net
What firmware do you have installed to the extender?
What sagecom router/combo device (model)? Does it use a smart connect function (one ssid name)? if so, shut it off.
- Rondo457May 11, 2019Aspirant
Hardwire into extender does not work.."unidentified network"....no internet/all lites green/ same response as wireless.Extender GUI 192.168.1.250 does work from Google/ChromeNo firmware installed...straight out of the box.Spectrum Sagemcom Router/ 802.11ac wave 2-askey routerModel# RAC2V1K. No smart connect function. I suspect this extendermodel has been around several years. Thanks again.
Thanks- Christian_RMay 16, 2019NETGEAR Employee Retired
Hello Rondo457,
Please try factory resetting the extender by pressing on the small black button using a pin for 15+ seconds and join the NETGEAR_EXT wifi network with a laptop or mobile device. After you connect to the network, browse to www.mywifiext.net and follow the setup instructions.
~Christian
- plemansMay 16, 2019Guru - Experienced User
You could upgrade the firmware prior to resetting, then do your rest, and then trying redoing your install. Its always good to do a factory reset after and firmware update. Here's the support page for the ex3700.
https://www.netgear.com/support/product/EX3700.aspx
the release notes for the firmware walk you through updating firmware
- Rondo457May 17, 2019Aspirant
Hi. Netware Genie printout indicates firmware v1.0.0.76 which is current.
Did not run another setup as has been done approx. 6 times most
recently by Netgear Support with no success with "No Internet" problem.
I noted another post asking about channels for 2G, 5G. Any connection
with my problem ?? Thanks
