Rondo457
May 10, 2019Aspirant
EX3700 connected but no internet
May 11, 2019Guru - Experienced User
if you hardwire into the extender, does it work?
Are you able to pull up the extenders gui from a browser (not genie)? mywifiext.net
What firmware do you have installed to the extender?
What sagecom router/combo device (model)? Does it use a smart connect function (one ssid name)? if so, shut it off.
Rondo457
May 12, 2019Aspirant
Hardwire into extender does not work.."unidentified network"....no internet
/all lites green/ same response as wireless.
Extender GUI 192.168.1.250 does work from Google/Chrome
No firmware installed...straight out of the box.
Spectrum Sagemcom Router/ 802.11ac wave 2-askey router
Model# RAC2V1K. No smart connect function. I suspect this extender
model has been around several years. Thanks again.
Thanks
Thanks
- Christian_RMay 16, 2019NETGEAR Employee Retired
Hello Rondo457,
Please try factory resetting the extender by pressing on the small black button using a pin for 15+ seconds and join the NETGEAR_EXT wifi network with a laptop or mobile device. After you connect to the network, browse to www.mywifiext.net and follow the setup instructions.
~Christian
- plemansMay 16, 2019Guru - Experienced User
You could upgrade the firmware prior to resetting, then do your rest, and then trying redoing your install. Its always good to do a factory reset after and firmware update. Here's the support page for the ex3700.
https://www.netgear.com/support/product/EX3700.aspx
the release notes for the firmware walk you through updating firmware
- Rondo457May 17, 2019Aspirant
Hi. Netware Genie printout indicates firmware v1.0.0.76 which is current.
Did not run another setup as has been done approx. 6 times most
recently by Netgear Support with no success with "No Internet" problem.
I noted another post asking about channels for 2G, 5G. Any connection
with my problem ?? Thanks
- Christian_RMay 21, 2019NETGEAR Employee Retired
Hi Rondo457,
Were you able to resolve your issue with support? Has support followed up on your case? If not, please send me a message with your case number and email address so I can have support follow up with you.
~Christian
