Lefty19
Sep 17, 2020Aspirant
EX3700 Connecting Issue
Hi, I am trying to set-up the SX3700 (AC750) through WEP. I get the blinking light on the extender and then go to my router (Motorola AC1900, Model MG7550) and press the WEP key. The extender blin...
- Sep 17, 2020
plemans I was able to get it to work but not on my PC. I connected to the Netgear website from my TV and it brought up the website and I was able to get 2.4 and 5.0 on to the router. All is good but there is still a problem with not being able to connect to https://www.mywifiext.com/.
Sep 17, 2020Guru - Experienced User
Log into the router and look at its attached devices (or equivelent for motorola) list. The extender should be listed with an IP address. Use that to connect to the extender.
Or simply factory reset it again and redo the install hardwired. It should let you setup both bands during the manual setup process.
Lefty19
