Mystrigue
Nov 25, 2020Aspirant
Ex3700 connection failure
Using an EX3700 with web browser setup. I am able to go through the setup wizard but it refuses to connect to my 5G. I know the password is correct. I have done the factory reset and tried again with ...
Mystrigue
Hi I'm connecting to a Hitron CGNM 2250 modem. During setup connection to the 2G appears to work, but the extender doesn't provide internet access for either bandwidth. I'm not sure about my firmware.
Nov 26, 2020Guru - Experienced User
Did you follow the wps method of install or using the installation assistant?
- MystrigueNov 26, 2020AspirantI followed the assistant. I did not use WPS.
- plemansNov 26, 2020Guru - Experienced User
Where is it failingg in the process?
- MystrigueNov 26, 2020AspirantAfter entering the passwords for the two bands. It tries to connect but says it is unable to connect to the 5G band. I tried skipping connecting to the band which allows the extender to activate its extended bands but there is no internet connectivity. I tried running the setup wizard again from this point but with the same results.
