walle637
Jan 21, 2022Tutor
EX3700 constantly needs to be rebooted
I have an EX3700 Wi-Fi booster. When it works, it works wonderfully. About every two hours, however, the connection just drops. The devices will still be "connected" to the booster, but it appears on...
walle637
Jan 22, 2022Tutor
My modem is a Ubee dvw32cb.
I used the installation assistant.
The firmware version on my booster is V1.0.0.94_1.0.61
Let me know if you need anything else. Thank you for replying!
Jan 23, 2022Guru - Experienced User
Looked up that router and its not exactly a rock star device. Not saying its the issue but its a pretty base model/poorly coded device.
- walle637Jan 23, 2022Tutor
Do you think there are any settings that I could change on the modem to help the modem->booster connection? I have access to the modem's internal settings.
- plemansJan 23, 2022Guru - Experienced User
you could try setting the extender with a static ip address in the router?
You could also try changing what wireless channel the router is broadcasting on in case there's interference.
