djkyky
Feb 06, 2020Aspirant
EX3700 extender 169 pre IP address error
Why am I getting a 169 pre IP Address (no web page loads) for auto connect on IPhone 8+ but IPhone 6S, Samsung 9+, laptop and other devices all connect to extender with no issues? Apple support h...
Feb 07, 2020Guru - Experienced User
It usually means something else on your network (other than your router) is acting as a DHCP host or that a IP address isn't being given to the device and its self assigning its own address.
does this 1 device connect to other wireless networks or does it work fine if its directly connecting to the router?
Usually when its only 1 device, we look at the device itself. Its its multiple device, then we look at router/extender.
- djkykyFeb 07, 2020Aspirant
Thank you for the response. The phone connects to the main cable router at home and works fine. I can connect to other WiFi spots such as WalMart, Lowes and Publics without issue, but when connected to places like Starbucks or other stores I cannot get the web pages to load. The Samsung phone works at all these locations.
This morning I went through the routine of resetting the extender, toggleing the Bluetooth, WiFi and airplane mode on the phone. I did get an IP address without the 169 prefix. Shows I am connected to extender, but Safari shows not Internet connection.
Thanks again for your help.
- plemansFeb 07, 2020Guru - Experienced User
djkyky wrote:Thank you for the response. The phone connects to the main cable router at home and works fine. I can connect to other WiFi spots such as WalMart, Lowes and Publics without issue, but when connected to places like Starbucks or other stores I cannot get the web pages to load. The Samsung phone works at all these locations.
I think its an issue with the phone. Especially when you have the problem at other locations like starbucks and other wifi spots.
Plus all your other devices work.
so to summary:
all other devices work without issue
only 1 device has the issue.
that specific device has issues on other wifi networks.
Really seems to point at it being that device.
- djkykyFeb 08, 2020Aspirant
I found and corrected the problem. You were correct the issue was not with the Netgear Extender. It was not even an issue with my phone. The problem was the main router/gateway/server had my IPhone blocked. I found the block in the settings and disabled and all is good. What was strange was my phone was not blocked when I connected to the main router but was blocked when I connected to the extender. The extender did not have the block setting enabled. I do not understand why.
I still have to determine why I have issues with other hotspot locations. I may still have an issue with a phone setting. Maybe it is signal strength.
Thanks for your help.
