NYPatti
Apr 26, 2020Aspirant
EX3700 EXTENDER WITH Apple Airport Express as router
I have my home WiFi via an Apple Airport Express(802.11n), on my MacMine running High Sierra10.13.6. I don't understand how to set up the extender, as I don't have means to wps on the airport express...
- Apr 27, 2020
Found a different work around--my iPhone liked NETGEAR_EXT
Apr 27, 2020Guru - Experienced User
use the smart installationsetup proces from netgear. The support site has a video that walks you through it. I think its the 2nd video
https://www.netgear.com/support/product/EX3700.aspx
the manual also has the walk through as well.
- NYPattiApr 27, 2020Aspirant
Watched video and still having issues because there is no place that shows NETGEAR_EXT on my computer
Is it supposed to show up on my Airport Utility as Other Wi Fi Device or is is supposed to be set up in System Preferences as a Wi-Fi network profile?
OR am I supposed to set it up in one of these places??
- plemansApr 27, 2020Guru - Experienced User
Not sure as its a mac.
the EX3700 does have an ethernet port you can hardwire in to do the setup. Just make sure to disable your wifi if your computer so its not defaulting back to the wifi during setup.
