monstro
Oct 04, 2019Aspirant
EX3700 not supporting 802.11n at all allthough promised in the datasheet
Although stated in the datasheet that the EX3700 is supporting • IEEE® 802.11 b/g/n 2,4 GHz • IEEE® 802.11 a/n/ac 5 GHz in reality EX3700 get's no connection to 802.11n WLANs (tested with differen...
monstro
Hi plemans,
thanks for the reply.
First I need to connect the range extenter to the router from which I want to extend the network. Right. Then after successfull connection it makses sense to connect some devices to the extender.
So fist step: The router is transmitting a 2,4 Ghz and a 5 Ghz WLAN both in n mode.
I try to connect the extender to each of them to extend the reach of it.
But the extender can connect to none of them.
Now second step I change the 2,4 GHz WLAN to g mode and the 5 GHz WLAN to a mode.
Now the extender is able to connect to both of them.
If as a third an last step I change back the 2,4 Ghz and a 5 Ghz WLAN to n mode the extender again looses the connection to the router.
So you see nothing crazy like a router - extender - router connection or so.
But the extender cannot connect in n mode to the router.
What security are you running on it?
=> WPA2
I use the range extender in repeater mode.
So this setup:
Router ---> WLAN1 ---> Range Extender ---> WLAN2 --->Devices
At the WLAN1 side I discover the inability to connect to n mode WLANs.
THX
Oct 04, 2019Guru - Experienced User
What router are you connecting to?
Firmware on the extender?
Do you have a different router that you could use to test with? it wouldn't be the first time a problem with an extender turned out to be a problem with a router.
I have this same extender connecting at my parents place to a dual band wireless n setup so I know its not a hardware limitation. I'd be betting on a incorrect setting causing issues.
