robinsubar1
Mar 06, 2022Follower
EX3700 password
I am simply trying to change the password on my EX-3700, or figure out what it is. I cannot log on to the site "my wifi ext" or the dot.com site as it times out when I try. Is there any way to reset and set up without the browser? Otherwise this is junk. Thank you!
1 Reply
You may want to look at the installation guide or user manual for the EX extender to help you with this.
A factory reset maybe needed and walk thru the setup wizard and be sure to write down all important information for safe keeping and use later on.
