DeathMark72
Feb 09, 2021Follower
EX3700 Range Extender - after reset cannot get mywifiest.net to work
HELP! I had to get new equipment (modem & router from Spectrum) for my home and after getting that set up I tried to update the new network/password in my at that time working EX3700. I tried doing t...
Feb 09, 2021Guru - Experienced User
A couple things you can try.
1. try hardwiring a pc/laptop into the extender to set it up. Disable the wifi on the pc/laptop so it doesn't default back to that connection
2. try a different browser. i've had luck with firefox working when others wouldnt
3. clear cookies/cache on the current pc.
