vampyre's avatar
vampyre
Follower
Jul 08, 2022
ex3700 reset button
hi
apologies if this is not the correct location, since it refers to a range
extender but it seemed most appropriate out of the possibles.
however, i want to factory reset a 2nd hand ex3700.
the manual says, use pen and press in the button on the base of the ex3700.
the glitch is i'm blind, and theres a lot of thigns on the base of the ex3700
that are divits u can stick a pen in but none seem to be factory reset
eg. on the ex2700, the factory reset button, actually presses in the the
other 2 physical buttons on the extender.
could anybody with some experience of this, give me a clue whereabouts on the
base the factory reset button is?
many thanks for any ideas forth coming.
1 Reply
  • plemans's avatar
    Its actually on the side of it. The snipped and and re-highlighted the spot on it for better viewing.
